Text Halo Shifts When Exporting from ArcMap
2724
08-07-2018 10:28 PM
RebeccaKing4
I'm having an issue with text halos in ArcMap 10.5.  They look fine in ArcMap but when I export to pdf, tif, jpg, eps etc the halo shifts (in my case the halo looks too small and squished in from the left and right behind the text).  I've tried changing fonts, exporting at different DPI, I have 0 spacing and I'm going bonkers trying to fix it.  Anyone have a solution? Thanks
Tags (1)
CharleneWagenaar
I'm having the exact same issue in the exact same version of ArcMap...
RebeccaKing4
I'm still yet to find a solution....
RebeccaKing6
Hi Charlene,
I fixed this issue.  I found the following technical article
https://support.esri.com/en/Products/Desktop/arcgis-desktop/arcmap/10-6-1#knowledge-base/technicalar...
ArcMap uses information from Windows' default printer and our server didn't have a printer installed.  Once I added the printer my export was fine.
Good luck
RebeccaKing4
Esri Technical Support‌ is there anyone who can help me with this text halo issue?
