shapefile creates on QGIS and opened on ArcMAP desktop doesn't open att. table
3096
03-28-2021 01:30 PM
YoavSHASHA
i have a shapefile that was created originally in QGIS
I'm opening it on my ArcGIS Desktop
but doesn't manage to open the Attribute table.
Can't understand what could be the problem,
when the same shape being open in QGIS, the Attribute is there
thanks in advance for the help
DanPatterson
MVP Esteemed Contributor
dbf is the table
it opens fine in ArcGIS Pro
... sort of retired...
JayantaPoddar
I can open the shapefile and its attribute table in ArcMap (10.8.1) as well. No issue at all.
I hope you are adding the shapefile to ArcMap via Add Data tool
or drag-n-drop from Catalog pane.
Do you receive any error message when you open the Attribute Table?
Think Location
JayantaPoddar
In case you are not able to see the attribute table dialog box at all (it should happen with other layers also), then please check Problem: ArcMap does not display the Attribute Table dialog box for a layer
Think Location
jcarlson
Are you opening the file in both programs at once?
- Josh Carlson
Kendall County GIS
DanPatterson
At least we have all ruled out file error.... must be a slow day 😉
