shape file
3849
8
01-25-2022 11:14 AM
NajmehServatsamarein2
Hello. I try to save a shapefile with the symbiology. so my coworkers can open it in their map. but any time they open the shape file they need to set the source. and after that the symbiology that I have created doesn't show. they need to symbiology again. I tried save as layer but still same problem. is there any other way ?
2 Solutions
AdrianWelsh
MVP Honored Contributor
What software are you using? In ArcGIS Pro you can save the shapefile as a Layer Package. This way all things get preserved in this process, including symbology.
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/layer-package.htm
David_Brooks
MVP Regular Contributor
@NajmehServatsamarein2 what software are you using? ArcMap or ArcGIS Pro?
Shapefiles don't support symbology, so when you set the symbology in Map or Pro, you'll need to export a layer file to accompany the shapefile. Then if the end user drags and drops in the layer file and repoints to the shapefile source, then you should be good to go.
Make sure you set the symbology on the shapefile you've exported. If you have symbology that's derived from ObjectID in a file geodatabase (for example), then you may lose the symbology as shapefile unique IDs are FID.
David
..Maps with no limits..
AdrianWelsh
I am using ArcMap 10.5.1
AdrianWelsh
That is good to know! Layer packages work in ArcMap too:
https://desktop.arcgis.com/en/arcmap/10.6/map/working-with-arcmap/creating-a-layer-package.htm
I know you said that you saved as a 'layer', but the layer package is more 'guaranteed' in my opinion!
so if I save as a layer package do they can change or edit?
AdrianWelsh
Yes. Once they import the layer package, it is theirs to make do with. They can do whatever they need to do. The benefit of the layer package with GIS files is that it will work for shapefiles, geodatabase feature classes, etc.
thank you very much!
David_Brooks
David
walnutriver
Shapefiles don't retain symbology when sending the shapefile to another person.
