Rotation of ArcMap marker symbols with data frame rotation
637
10-13-2022 06:52 AM
Geo_Vermeer69
Hello community,
I would like to ask for your help on an issue that is already known, but where the solutions I have found do not work.
I am using ArcDesktop version 10.6 and the symbolisation of my polygon layer, hatches in different angles e.g. 0°, 45° and 90°, rotate within the data frame in the polygon.
As a result, their angle no longer matches the angle symbolisation in the legend.
I already tried this solution (uncheck the "Rotate markers symbols with data frame" in ArcMap Advanced Settings Utility)
https://support.esri.com/en/technical-article/000002834
After restarting ArcMap 10.6 the hatches do rotate again.
Does anybody know a practical solution? Thank you very much!
