Permanent ArcGIS Desktop license stopped working
4514
9
04-16-2019 04:30 AM
khalidmwakoba
Hi everyone,
I have a perpetual/permanent ArcGIS desktop licence under the SCGIS conservation program which worked for few months before it recently stopped working. When I try to launch it I get the message which says 'my license is in need of a repair operation, access the ArcGIS administrator to repair your licences'. All the extensions show they are still up to date and I don't see an option of repairing it on the administrator though I unsuccessfully did try to repair it through uninstall> repair. While I was on the ArcGIS administrator I could see that the authorization status of the desktop is "untrusted" and not 'yes' like the extensions. My customer number is 575586.
Thanks for helping.
Christopher28
Hello,
you can optionally delete the trust storage and reset and reauthorize the license via myesri and the function "Restore lost license".
How To: Clear or delete trusted storage for concurrent-use and single-use licenses
DanPatterson_Retired
TimCraig
Hi Dan - That change isn't being applied until 9 PM this evening.
Also, that update won't affect licensing.
Ahhh … I new it was today somewhere yesterday so I wasn't sure if it was local time rollout or Redlands
Ruled one issue out at least
khalidmwakoba
It stopped working couple of weeks ago and not yesterday
MelitaKennedy
Esri Notable Contributor
What software version do you have? Have you recently updated the operating system?
Melita
MelitaKennedy
If you're on 10.3.1, and upgraded to Windows 10, check out this technical article: https://support.esri.com/en/technical-article/000013232
khalidmwakoba
Hi, I use 10.6 on windows 7 professional and i have never updated it before.
Christopher28
Hello,
khalidmwakoba
After following the article it worked out without any problem.
Thanks
