Percentage Change Calculation
4884
06-12-2020 01:12 PM
MichelleCouden
Trying to calculate percentage change in numbers from year 2019 to 2020. The calculation in the field calculator should be 2020 - 2019 = divided by 2019. I have tried several ways but it is not showing the correct answer. Here is what I have 4244 - 6363 = -2119 / 6363 shows -.33 percent change. [Volume_2020] - [Volume_2019] / [Volume_2019] but it gives me the answer of 4243. Am I missing same quotations?
GeoJosh
Hi Michelle,
The first portion of the formula needs to be in parentheses like this:
([Volume_2020] - [Volume_2019]) / [Volume_2019]
Otherwise, the division will be performed before the subtraction due to order of operations. Let me know if this works!
Best,
Josh
GeoJosh
Hi Michelle,
Best,
Josh
MichelleCouden
Thanks. I was using brackets not parentheses. I’ll try that.
MichelleCouden
It didn’t work. It said it didn’t like the Type Mismatch.
MichelleCouden
It worked. For some reason, it was not working inside my geodatabase. So I took it out and then did the calculation. Thanks for the help.
