Label Expression
1491
03-17-2021 02:22 PM
ivyhinson12
I need to create a label expression where only the largest of three columns is displayed. The columns are: [CP_N], [CP_S] ,[CP_W]
Please help!
jcarlson
Do you have a preference as to which label expression profile is being used? You've got the python and vbscript tags both on here.
In the expression, try something like this:
def FindLabel ( ):
    a, b, c = [CP_N], [CP_S], [CP_W]
    if a > b and a > c:
        return a
    elif b > c:
        return b
    else:
        return c
FindLabel()
- Josh Carlson
Kendall County GIS
RobertBorchert
Honored Contributor
That is a very good answer.
DougBrowning
MVP Esteemed Contributor
What product is this for?  You posted to the Survey123 board.
thanks
