I am trying to join and .xlsx table to an attribute table so I can copy features from the Excel table. However
when I go to bring the Excel table into my map, I get the, 'Failed to Connect to database error. An underlying database error occurred. Class not registered.' So I googled the error message and it said you need to download the Microsoft driver for your computer. So I downloaded the 'Accessdatabaseengine_X64.exe' driver from the Microsoft website and installed it on my computer. Then I tried bringing the .xlsx document into my map again but still got the same error message.
How can I resolve this? Should I try installing the 32 bit version and see if that works?
And you're using ArcMap, but you have a Windows 10 64 Bit os, right? You can try the 32 bit version but you're on you own. I don't even know if ArcMap will recognize .xlsx worksheets.
This is one of the many problems that goes away when you migrate from ArcGIS Arcmap and to ArcGIS Pro.
My suggestion would be to use the excel to table tool first and then join the resulting table.
I agree with Joe. Even though you can join directly to an Excel sheet, I find it causes more unexpected errors. As someone that does tech support, this is a common problem that our GIS users see. Import excel to table first, then join.
I ran into another issue.
The table I am trying to join has x, y coordinates in it and I need to geocode some new points in the Excel table in my map.
The way I usually do this is by just right clicking the Excel table in the TOC and Display XY coordinates but since I can't bring the Excel sheet in my map, I can't do this. Can you still use your method to geocode x, y coordinates?
Yep; I try to avoid using Excel worksheets as a data source as much as I can. Convert it to a table and you are good to go.
the Table to Table conversion tool doesn't even let me add the Excel table as an input. It gives me the above error message.
Thank you for that suggestion!
I can just do what I want in Pro
The agency I work for is strictly an ArcGIS Pro shop; I don't even have ArcMap installed, and haven't for nearly 2 years. My motto is go Pro or go home....
You might need to silent install the 32-bit driver (from command line as opposed to from the GUI) in order to allow ArcMap which is a 32-bit program to connect to excel.
