insert space into string with Field Calculator
2476
08-27-2021 01:18 PM
JasonFitzsimmons
I am using ArcMap 10.7.1. This seems like it should be easy so maybe I am missing something.
I want to insert a space into a string between specific parts of the string using Field Calculator:
!FIELD! .replace("F'target", "F' target")
Neither 'F' or 'target' are at beginning or end of string, those characters are in the middle of a string.
I run the calculation, and nothing happens. I've tried to escape the single quote, but no difference. Do I need a wildcard tag at beginning and end of the substring?
I have tried this with VB and Python..I can change other string values in the same table.
JasonFitzsimmons
I found the problem, the first single quote was " ‘ " instead of " ' "
Not sure how that got there but that was it
JayantaPoddar
Could you share screenshot of the present values in the corresponding field of the attribute table? Do you have an apostrophe between F and target (e.g. F'target)?
Think Location
JasonFitzsimmons
