Importing excel spreadsheet
2525
03-01-2021 02:23 PM
JamesPetty
I have imported an excel spreadsheet into ArcMap. The points are showing up but when I turn on the base map the points disappear. It automatically zooms in really close, 1:3. When I try to zoom out to 1:24,000 It shows a black screen with one red dot.  What am I doing wrong and what do I need to do to correct the problem. I am pretty new to this, so please be kind.
2 Solutions
DavinWalker2
Hi James,
It sounds like the layer with the points that you have imported doesn't have a spatial reference defined.
Use the define projection tool to define the coordinate system information (map projection and datum) stored within the dataset. Define Projection
JamesPetty
Davin,
Thank you for the information.  I thought I had set the projection correctly when I added the data. Maybe I didn't. I have it set to NAD1983, NAD 1983 UTM Zone 13N. I pulled the information from a picture on my cell phone. When I created the excel spread sheet I set the x axis as -101.1760000 and y axis 29.5370000 is this not correct? When I open the picture in maps on my phone this is the location it gives me, maybe this isn't in UTM's. How would  I find out what the projection needs to be? I appreciate the help
DavinWalker2
Hi James,
JamesPetty
Davin,
DanPatterson
MVP Esteemed Contributor
Those coordinates are longitude and latitude, they could be in a GCS WGS 84 or GCS NAD83
but they are "geographic" not "projected"
... sort of retired...
