HI, I'm Michael. I'm currently working on the attribute table of a map but I clicked on 'show selected records' after which I clicked 'show all records' However, it keeps showing only selected records as in the attached file. I've uninstalled and re-installed ArcGIS but cannot still view all records from the map attribute table. I've also used the 'table option' to 'clear selection' and 'select all' and haven't seen all records. Please can someone advise me on what to do? Thanks
Right click, then Selection, Select All, don't forget Clear Selection first.
Thanks, JinMa2. Please where do I right-click?
on your feature class
I've done that from the 'table options' but it didn't still show all records
did you clear selection? What feature class is it?
Please I cleared all selections and still do not see all records. I don't understand what is feature class.
It shows "1 out of 1 selected", so your table only has that one row.
It previously showed two before I clicked 'show selected record' and it has refused to show the next record. I want to use it in determining predicted areas and observed areas in species distribution modeling of several crops. And the previous attachment is just one of the species
Maybe you accidentally deleted the other features when you tried to make them appear again?
Do you still have the original data? Then try to load that into ArcMap.
