How to remove right spaces on a field selected to create symbology -> catagories -> unique
1071
04-19-2022 04:58 AM
JoseSanchez
Hello everyone,
I added a layer in a map and created unique categories selecting a text field. The problem now is that this field sometimes has blank spaces on the right so the values are not selected.
Is there a way to truncate all empty characters from a text field in the symbology section?
RobertBorchert
Honored Contributor
You will need to remove the spaces in the table.
the trim command should remove leading and trailing spaces from a field in a calculate field
trim($feature.<field>)
DanPatterson
MVP Esteemed Contributor
or with the python parser, there are lots of options ...
a = "your field   "
a.strip()
'your field'
b = "    your field   "
b.strip()
'your field'
c = "    your field   "
c.rstrip()
'    your field'
c.lstrip()
'your field   '
... sort of retired...
