how to fix an overlapping boundary
3334
05-30-2023 11:47 AM
HannahLacey
I am using ArcMap 10.8.1
I have a shapefile that has several polygons within it delineating different forest stand boundary within a greater area.
I want to display all the stands individually with a thick boundary line of a unique color and a hollow fill. I used symbology to achieve this, but I am having problems with overlap. Many of the stand boundaries overlap and one color goes over the other. I am looking for a side by side display of the two boundaries not any overlap. I tried clipping but it ended up deleting or removing the part of the stand boundaries that touched or the whole boundary altogether.
I need some type of trick to show two boundaries side by side from within the same polygon. Is this possible?
Thank you for the help!!
DavidPike
MVP Notable Contributor
Possible Integrate https://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/integrate.htm but take a copy of the data as it modifies the input.
JimCousins
MVP Alum
You need to choose a feature attribute hierarchy. What you create with overlay analysis requires this as a follow up process, as it will return the overlap as a separate polygon. If you can not create a hierarchy, then run a union analysis, and display the overlap as a different symbology to indicate your area of uncertainty.
Regards.
