how to copy attributes with different names into new shape file?
2108
03-09-2021 06:56 AM
chrisvoegeli
Hello Community
I have a problem, moving polygon features from one layer into another layer while keeping attribute values. Some of the attribute fields have identical names others have the name changed:
Polygon1                Polyton2_new
Attribute_A    ->     Attribute_A
Attribute_B    ->     Attribute_C
Attribute_C    ->    Attribute_D
If I just copy and paste the polygon features, only the attribute values of the matching attribute names are copied, others are not copied to the new polygon layer. If I use "spatial attribute mapping" its a LOT of work, as I have about 1000 features. If I use "Spatial Join", I get another layer (e.g. polygon3) and its a lot of work to identify and specify which attribute values should be assigned to which new attributes.
Is there a simple way to copy all features including their geomerties from polygon1-layer with attributes A, B, C into an existing (but empty) polygon2 layer with attributes A, C, D where A1 = A2, B1 = C2 and C1 = D2 values should be copied/moved?
I hope my explanation is more or less understandable  🙂 Thanks for your help!
chris
DrVSSKiran
Chris,
Follow some simple steps.
1. Generate unique id in both the polygons.
2. Copy polygon fearures B to polygon A
3. Now export polygon B table as a CSV
4. Join attributes based on unique id which you were generated previpusly
5. Delete unwanted table columns if something is there.
Hope this works
DavidPike
MVP Notable Contributor
The Append tool should do the trick (make a copy of your data first!).
Append (Data Management)—ArcGIS Pro | Documentation
You control the input field going to the output field via the fieldmappings.
