How could I get information to know which tables used for each layer ?
4766
11
05-07-2023 06:29 PM
spiderman90
I would like to get information from each layer .
Each feature class read different data from different tables at my database .
How could I get  information  to know which tables used for each layer in ArcMap ?
spiderman90
As your example , you have centerlines as table .
but in my case , the name here is not the same name of table at my database .
May be 5 tables are providing data for layer and other layer get the data from others tables .
in my case ,if I select on a cable as example then check the log file .
It shows me in the log file, that many functions used to show the data on cable .
select * from table a
select * from table b
i mean , each layer getting the data from different tables at my database ,how could I see that tables name that joined to bring the data on layer ?
RhettZufelt
MVP Notable Contributor
So, sounds like maybe you have a combination of layer with joins and/or views going on.
List by source will show you all layers AND tables that are currently loaded into your map document (image show View, Table, and Feature Class):
You can right click the layer in ArcMap, properties, source tab to show you the layer/table name/location:
If you have joins or relates, you can look in the Joins and Relates tab to see what tables are joined or related:
For views, you can find the data location in the source tab, then get properties in ArcCatalog, the definition will show the SQL that creates the view:
And if you have relationship classes set up in the database, you can get that info from the Relationships tab in the properties in ArcCatalog.
R_
