How can I change the default annotation reference scale for a data frame in ArcMap without using VBA?
1040
08-17-2020 01:44 AM
JosephRigley
I'm working with some old MXD files that were imported from ArcView 3.2 and so have a reference scale applied to the default annotation group. There is a way to reset this via VBS, but that is not an option for me. How else can I reset this?
Egge-Jan_Pollé
Hi Joseph Rigley,
You should be able to access the Annotation Groups settings in the Data Frame Properties dialog.
HTH,
Egge-Jan
JosephRigley
This does not allow change of the reference scale for <Default> group, which is what is needed.
