Find Tool Locking Up ArcMap 10.3.1
3534
11
09-11-2018 04:43 AM
GlennG
I'm using my find tool like I've done in the past to search for a record and then have the tool zoom to that feature.  Everything is the same as in the past until I try to left click on the found feature so that I can zoom to that feature.  When I right click on the found record, I just get the turning wheel of death.  No options pop up, and the software seems to lock up.  Anyone ever have this issue just start out of the blue???
DanPatterson_Retired
If upgrade in arcmap is possible...
BUG-000090993: The Find tool in ArcMap hangs or crashes when used o..
fixed in 10.4
or...
Instead of searching through all fields with the Find tool, specify a search field.
GlennG
Dan, we should probably upgrade. And it is crashing when a field is specified.
Thanks.
Upgrade... and get moving on ArcGIS Pro
MichaelVolz
Esteemed Contributor
Are you searching data in an SDE Oracle database?
GlennG
The data is in a file geodatabase, but not on a server. I also tried to export the data from the gdb into a shapefile to see if it was an issue with the gdb, but still had the issue.
Glenn Gorman
GIS Analyst, Planning
Charles County Government
200 Baltimore Street
LaPlata, MD 20646
(301)396-5845
MichaelVolz
That is interesting because the bug is associated with an Oracle database, but it does appear to be wider in scope than the bug documentation.  This bug would only be fixed with an upgrade unless you specify a field and 10.3.1 is getting dated at this point.  Do you have the ability to upgrade your GIS software?
GlennG
Unfortunately, The folks in my IT department control version updates. We always seem to lag quite a bit as far as updates. I’ve been told they like to wait for bugs to be ironed out with newer versions, and then there have been other issues I think. But I’ll check with IT and see what plans are in the works to get an update.
Thanks
RandallWilliams
If it helps to support an upgrade case, ArcGIS 10.3.1 will be in mature support in December of this year, meaning no new patches or service packs will be released for this version.
https://support.esri.com/en/Products/Desktop/arcgis-desktop/arcmap/10-3-1#product-support
GlennG
Thanks for the info.
