Hello Community!
First time posting.
Is it possible to extract characters after another character such as a hyphen? For example, I would like to extract STMH4120 from STMH4870-STMH4120 and place in a new field.
Thank you.
JD
Solved! Go to Solution.
sue, just use field calculator and python
Making simple field calculations—Help | ArcGIS Desktop
Calculate Field examples—Help | ArcGIS Desktop
!your_field_name!.split('-')[1]
That indicates that not all of your records follow that convention and it's choking on a value that does not. You might want to first make a selection where:
YourFieldName like "%-%"
That will get only those records that David's expression can calculate.
Thank you, Joe. That did it. And thank you David!
JD
