Extracting Characters To The Right of a Hyphen
4961
06-22-2021 11:18 AM
JD1016
Hello Community!
First time posting.
Is it possible to extract characters after another character such as a hyphen?  For example, I would like to extract STMH4120 from STMH4870-STMH4120 and place in a new field.
Thank you.
JD
2 Solutions
DavidPike
MVP Notable Contributor
JoeBorgione
That indicates that not all of your records follow that convention and it's choking on a value that does not.  You might want to first make a selection where:
YourFieldName like "%-%"
That will get only those records that David's expression can calculate.
That should just about do it....
DavidPike
sue, just use field calculator and python
Making simple field calculations—Help | ArcGIS Desktop
Calculate Field examples—Help | ArcGIS Desktop
!your_field_name!.split('-')[1]
JD1016
Hi David,
Python is enabled in Field Calculator, my new field is called DwnStrmMH and these new values will be based on splitting another fields value.  I've entered !FacilityID!.split('-')[1] and an error message comes back (please see attached).
Thanks.
JD
JoeBorgione
JD1016
Thank you, Joe.  That did it.  And thank you David!
JD
