ECW support lost in ArcMap 10.8.2
14873
7
01-10-2022 08:10 PM
by Anonymous User
Not applicable
Hello.
A warning that upgrading from ArcMap 10.8.1 to 10.8.2 has broken support for ECW images.
Is there a timeline for when this will be fixed? ECWs are critical to my work.
This happened with ArcMap 10.6 as well, and ESRI supplied a patch. Possibly the issue is the same, and hence quickly patchable?
Kind regards
David
DanPatterson
MVP Esteemed Contributor
If this is the issue
BUG-000145463: Unable to load raster Enhanced Compression Wavelet (.. (esri.com)
click on the Subscribe link to receive notification when it is fixed
... sort of retired...
DanPatterson
ColLloyd
same issue, any body have solution
josborns
Solution until the patch is available:
Windows Registry Editor Version 5.00
[-HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\ESRI\Desktop10.8\Raster\Preferences]
[HKEY_USERS\S-1-5-21-012345678-012345678-012345678-12345\SOFTWARE\ESRI\Desktop10.8\Raster\Formats]
"0x59b9e63"="<e on=\"y\" nm=\"ER Mapper ECW\" ex=\"*.ecw\" />"
Forgot to mention;
The 'S-1-5-21-012345678-012345678-012345678-12345' bit may differ depending on your Windows version or edition, so have to look that up first.
UlfMerkell
UlfMerkell
GarrettByrd
This patch worked for ArcMap 10.8.2, but I still cannot view ECW files in ArcReader 10.8.2.
HS_PolkGIS
Any solutions for ArcReader 10.8.2...?
Edit: Per ESRI, the bug will not be addressed in ArcReader.
https://support.esri.com/en-us/bug/published-map-files-pmf-created-with-enhanced-compressi-bug-00015...
