Custom Transformation Files, folder location
1128
04-14-2021 04:05 PM
MichaelBarker
I'm creating custom transformation files in ArcMAP v10.8.1 and currently these are being written out to the user profile local temp folder, rather than the Roaming...\ArcToolbox\CustomTransformations folder.  Help indicates its a write issue and therefore defaulting to temp.  I've no problem copying the gtf file from temp to the roaming folder, but this isn't picked up when I need to apply the transformation (still looking in temp I guess).
Is there a way to permanently set (system variable?) where the custom gtf files are sourced?  We have a large number of users that make use of these transformations, so a centralized or more easily accessible folder would be ideal.
Thanks in advance for your help.
Michael.
