'Create Sink Structures' Error
1319
02-18-2021 01:37 PM
Labels (2)
KennedyReyes
Hello,
I am using ArcHydro on ArcMap 10.5.1
I am trying to delineate a map I have to determine water drainage areas, low lying areas, and direction of the water flow. I am following this tutorial: Arc Hydro - Identifying and Managing Sinks.pdf (esri.com)
So far, I have completed the following steps: Sink Prescreening, Sink Evaluation, Sink Selection. I am trying to use the 'Create Sink Structures' function but I keep getting this error message:
Start Time: Thu Feb 18 15:33:54 2021
Running script CreateSinkStructures...
('line 819', 'c:\\program files (x86)\\arcgis\\desktop10.5\\ArcToolbox\\Scripts\\ArcHydro\\CreateSinkStructures.py', 'RuntimeError: Object: Error in getting parameter as text')
Completed script CreateSinkStructures...
Failed to execute (CreateSinkStructures).
Failed at Thu Feb 18 15:33:54 2021 (Elapsed Time: 0.24 seconds)
Does anyone have any thoughts on how I can solve this issue?
Thanks!
DanPatterson
MVP Esteemed Contributor
I moved it to the ArcMap space in the Community.  That might help find someone that uses it and ArcHydro
... sort of retired...
