Count Duplicates in a Field for sequential unique ID
4078
05-10-2021 04:45 PM
GabriellaSantana
I am trying to create a unique ID for my street feature class. (My unique ID starts with first 3 letters of the Street Name, 2 letters of the Street type, and 3 letters of the City Name Abbreviated.) Where I am stuck is that I am trying to get a number to increment on the segments that would be duplicated. For example, Glenacre Drive has three segments. The UniqueID would be GLEDRHQF01, GLEDRHQF02, GELDRHQF03. I cant figure out how to create sequential numbers not based off of the ObjectID sorting... For example I used the following Field Calculator but realized it is looking at the ObjectID sort and my streets aren't entered in order...
Pre-Logic Script Code:
prevFieldValue = '' counter = 1 def GetDuplicateCounter(myFieldValue): global prevFieldValue global counter if myFieldValue == prevFieldValue: counter += 1 else: counter = 1 prevFieldValue = myFieldValue return counter
= GetDuplicateCounter( !UNIQUEID! )
Any Help would be Amazing! 🙂
JoshuaBixby
MVP Esteemed Contributor
Something like this should work in the interactive Python window:
lyr = # name of layer or path to data set
with arcpy.da.UpdateCursor(lyr, "UNIQUEID", sql_clause=(None, "ORDER BY UNIQUEID")) as cur:
    cnt = 1
    uid, = next(cur)
    cur.updateRow(["{}{:02}".format(uid,cnt)])
    uid_prev = uid
    for uid, in cur:
        if uid == uid_prev:
            cnt += 1
        else:
            cnt = 1
        uid_prev = uid
JohannesLindner
Define a dictionary that relates the string part of the id to the corresponding counter:
duplicates = {"GLEDRHQF": 3}
def get_duplicate_counter(value):
    try:
        counter = duplicates[value] + 1
    except KeyError:
        counter = 1
    duplicates[value] = counter
    return counter
    # or directly return the complete id:
    # return "{}{:02d}".format(value, counter)
Have a great day!
Johannes
JoshuaBixby
    cnt = 1
    uid, = next(cur)
    uid_prev = uid
    for uid, in cur:
        if uid == uid_prev:
            cnt += 1
        else:
            cnt = 1
        uid_prev = uid
GabriellaSantana
Thank you so much! Is there a way for me to make this create a new field and populate it?
JoshuaBixby
Just use Add Field (Data Management)—ArcMap | Documentation (arcgis.com) upstream of the code snippet I provided, and then adjust the cursor to work with the necessary fields.
GabriellaSantana
Thank you!!
