Conditional evaluation with Con
2028
05-10-2021 12:38 PM
GJB
Hello, in ArcGIS 10. used geologic boring logs and the topo to raster tool to create a BedrockElevation raster.  However, some bedrock outcrop areas were interpolated to be at an elevation ‘higher’ than the GroundDEM, so I need to adjust these areas to actual ground elevation.  What is the best way to accomplish this?  It seems easy in concept but I’m having trouble making a formula to work in Raster Calculator. Any insight would be greatly appreciated. Thank you.
Concept:  New Raster =
IF: "BedrockElevation" > “groundDEM”
THEN: assign elevation value from "groundDEM"
OTHEWISE: keep the elevation value of "BedrockElevation"
I tried: CON("BedrockElevation" > "GroundDEM", "GroundDEM", "BedrockElevation")
JayantaPoddar
Functions are case-sensitive. Could you test
Con(("BedrockElevation" > "GroundDEM"), "GroundDEM", "BedrockElevation")
Let us know if you have any further issue?
Think Location
JayantaPoddar
Think Location
DanPatterson
MVP Esteemed Contributor
Do you have a screengrab/text result of the actual expression?
Presumably you got an error or an unexpected result.  Could you report which and what.
... sort of retired...
GJB
Thank you for the response!!  It was solved as above.
GJB
Yes!  That was it, thank you for the response!
