Convert a text field to a numeric field
26950
7
01-26-2022 07:25 AM
mkhenson
I have a shape file that was exported from Autocad Map.  It represents pipes in a network.  I have a field representing the pipe dia, but it is a text field and would like to convert it to numeric.  Can someone walk me thru those steps?  Name of the text field is "LAYER" and I need the new numeric one to be "DIA"  Thanks for any help you can give.
MKH
3 Solutions
JayantaPoddar
As mentioned by Sean, you need to add a field "DIA" with Type LONG INTEGER or FLOAT, depending on whether the desired value is an integer or Decimal Point value respectively.
Then Right-click "DIA" field > Field Calculator.
Expression:
[LAYER]
Think Location
AdrianWelsh
MVP Honored Contributor
The first thing you need to do is Add a Field and make sure you make it numeric. If you just need integers (whole numbers), choose Long as the data type. If you need a floating point decimal, choose Double as the data type:
Now that you have this new field, DIA, right click on it and choose "Calculate Field":
If you need to convert to an integer, in the field calculation box type this:
int(!LAYER!)
If it's a floating point, type this:
float(!LAYER!)
 Make sure Python 3 is chosen as your Expression Type:
Sean_Wray
Yes - my apologies for the rushed answer...
In ArcMap open your table. On the drop down choose Add Field.
Name it - define it as double
The right click the new field name in the table and choose Field Calculator
A box will popup. The field you are calculating will be populated. See in the screenshot where it says TEST=. Then in the fields box, double click the field name you want to copy the data from. In the example I choose X and click OK
Sean_Wray
You can use the add field tool and then use the field calculator to calculate what goes in it.
https://desktop.arcgis.com/en/arcmap/10.3/tools/data-management-toolbox/add-field.htm
mkhenson
yeah, I've seen the help, but it reads like a programming language, which confuses me entirely!
AdrianWelsh
int(!LAYER!)
float(!LAYER!)
JayantaPoddar
Expression:
[LAYER]
Think Location
mkhenson
Thanks very much.  I appreciate the replies!
Sean_Wray
mkhenson
Thanks Sean...that's perfect!  I appreciate it very much
