Cannot read LAS file in ArcMap
1827
02-25-2021 05:33 AM
BrianBulla
Honored Contributor
I've got an LAS file that works fine in ArcGIS Pro, but in ArcMap 10.4 (with 3D Analyst extension enabled) I cannot even see the dataset in Catalog to add it as a layer.  Neither ArcMap nor ArcScene can see this LAS file.
Any ideas what I am doing wrong??
Tags (1)
tigerwoulds
I dont think older version of ArcMap are capable of reading LAS files directly. Use your LAS files and create a LAS Dataset. Then you should be able to view the points, tile boundaries, ect.
Creating a LAS dataset—Help | ArcGIS Desktop
tigerwoulds
BrianBulla
Honored Contributor
Thanks "Tiger".  That seems to have fixed things.
