Can't drag and drop an XLS table in ArcMap 10.5.1
7691
9
10-21-2017 02:12 PM
CarlBeyerhelm1
I recently upgraded to 10.5.1 from 10.3.1 and have noticed that I can no longer drag and drop an XLS table into ArcMap 10.5.1 like I was able to do in 10.3.1.  I get a "Failed to connect..." message, as illustrated below.  But I can drag and drop an XLSX, but I have to open the XLS in Excel first and save it as an XLSX...a bit inconvenient.
Is that a bug, or do I have a dodgy install of 10.5.1, or do I need to make a setting somewhere to be able to drag and drop and XLS, or is that just the way it is?
Thanks.
This message is produced when I drag and drop an XLS table in ArcMap 10.5.1.
DanPatterson_Retired
from recent reports.... get used to it... search this site using the error and you will find some threads indicating there was a non-fix, then...
https://community.esri.com/message/722098-unexpected-error-from-the-external-database-driver-1
CarlBeyerhelm1
OK.  Thanks for the speedy reply.
So one wonders now if the Table To Excel tool will be re-jiggered to output XLSX...
Try using the excel to table tool drag and drop is a convenience, but not an optimal approach... also
Excel To Table supports Excel Workbooks (.xlsx) and Microsoft Excel 5.0/95 Workbook (.xls) formats as input.
UPDATE...
Forgot about the Oct 17 Windows update.
Hot of the press.....
http://support.esri.com/en/technical-article/000016969
CarlBeyerhelm1
OK.  Thank you for the follow-up.
I did apply the 2007 Office System driver as per the technical article cited in your link above.  In my case, however, it did not have the desired effect.  Nevertheless, I appreciate the info.
AZendel
The fix mentioned in this article corrected the problem for me. I can now read XLS files in ArcMap/Cat
good, and people with more recent windows updates shouldn't then experience that problem either.
AZendel
We had to 'pause' updates in our office because of conflicts with our antivirus.  So the fix didn't get rolled out to my computer when other Win7/10 users probably received updates.
curtvprice
Excel : useful analysis environment -- but a terrible database. Getting data types to come in the way you want, and getting data in without modification can require creating a new tab, pasting data as values, formatting data types, then export to .csv to get things to load up correctly. Usually it's easier, but the fact is Excel is not a database and we really shouldn't try to use it as one.
