CAN NOT CLIP!!
731
09-23-2024 11:59 AM
Goldenbeefburger
I NEED YOUR KIND LIGHTS!!
I'm making a survey regarding the NBR index in the municipality of rethymno (Crete). As you can see, i have my municipality shp (export_output10) and my custom made index.
Yes every coordinate system is the same (.shp, the sat data, the view etc.). I have been trying to clip with every possible way the index into the shapefile. I've tried putting the .shp above it, below it, even in the settings but came to no result.
Clipping results in a blank raster, with completely different values out of my index and its showing up nowhere. Any help would be appreciated!
(screenshot as a link)https://prnt.sc/NX6ypg5JAeui
Goldenbeefburger
(*) i have also tried by masking but led to no result...
