boy I hate the licensing method for ESRI products
1199
06-25-2023 07:43 PM
GrahamWarden
ArcMap 10.8.2
The Availability of Spatial Analyst shows up in the Lic Manager, yet I still can't use Spatial Analyst. (expiry = 4/4/24)
I have a 'home' version and for the most part cannot use it because it is so difficult to get access even if you spend hours trying to figure out the Lic Manager. And there is no real support.
When I try to 'reload' licenses, it says I no longer have any more to licence.
ESRI support is useless with this.
What to do?
JohnPlunkett
Hi Graham,
If you open ArcMap
Click Customize >  Extensions
Then you can click the check boxes for the extensions.
Click Close and then you should be good to go
Using Extensions in ArcGIS—ArcMap | Documentation
Documentation reference above 🙂
