How to export some feature classes from arcmap into file geodatabase including domains and subtypes ?
1110
06-23-2023 05:30 AM
spiderman90
Hello ,
i would like to export  some feature classes from arcmap including domain and subtypes in file geodatabase format ?
Thanks in advance .
I have tried with arc catalog but it allows me only to get xml document but not file geodatabase ,i am not sure why .
is there other method instead arccatalog ?
how to check later that file geodatabase has domain and subtypes as expected ?
RhettZufelt
MVP Notable Contributor
Use ArcCatlog, copy the featurclass, paste to the FGDB.
ArcCatlog copy/paste will preserve all the domains/subtypes.  Get properties of the FGDB will show you the domains, look at subtypes in the featureclass properties to see subtypes.
R_
