axtiveX error warning
37156
25
04-30-2017 10:00 AM
ClintonJenkins
New Contributor III
I am having the infamous activeX warning appearing again with all my toolboxes in ArcMap 10.5, but only when I click in an empty field. This started only recently, and I think it may be linked with the recent Windows 10 Creators Update. I've tried the traditional solution of adjusting the Internet Options, but with no success. Is anyone else having this difficulty?
PrasantaBhattarai
Thanks @Dan Patterson for the correction!
ClintonJenkins
New Contributor III
That appears to solve the problem. Thanks for looking into it Prasanta!
RandyKreuziger
Occasional Contributor III
Will these two files work with 10.4.1?
TracyThorleifson
New Contributor III
Prasanta,
I'm running ArcGIS 10.5.1.7333 and Windows 10 Pro v.1709 (Build 16299.431) and the .xsl update fix is not working for me.
Tracy
DavidWheelock2
Prasanta Bhattarai‌'s fix worked for us today!
Amanda__Huber
MVP Regular Contributor
I am experiencing this same issue in 10.6 of ArcMap
ThomasNydegger
Works for me too. Thanks.
JamiDennis
New Contributor III
This fix did not work for me on 10.5.1.7333 - so I upgraded to 10.6 and that resolved the ActiveX warning message.
MichaelVolz
Esteemed Contributor
Does this issue not occur if you have not installed "Windows 10 version 1703 (Creators Update)" onto a Windows 10 computer?
Is there a way to check if this "Creators Update" has been installed on a computer?  Somewhere in Control Panel for an administrator on the computer?
JamiDennis
New Contributor III
I guess it isn't possible to test that now since I already upgraded to 10.6  and the issue appears to be resolved - but to see if the update has been installed, I am not sure how to find that. Here is a screenshot of the Windows updates that are installed on my windows 10 Pro machine.  I tried searching the control panel for that but no luck.   I have version 1709 (OS Build 16299.248) does that help?
windows updates screenshot
