ArcMap opening on wrong monitor
2482
01-27-2021 02:22 PM
JustinLor
Hi. I am using dual monitors and I just want ArcMap to open on my left monitor but it always opens on the right hand side.
I've tried placing the MXD location on the left monitor and the right but it always opens on the right.
KevinHigh
Found this on another community post. It works for me:
Correct Answer
This might seem crazy but...
1. Make ArcMap smaller than full screen.
2. Drag it onto your primary monitor and close ArcMap (without maximizing).  When it reopens, it should be on your primary monitor.
3. Maximize ArcMap on your primary monitor.  Close ArcMap.
4. When you reopen a second time it should be maximized on your primary monitor.
DanPatterson
MVP Esteemed Contributor
You tried all the Dr Google suggestions?  Maybe Arcmap doesn't behave like other applications though.
However, there is a solution
Hidden or Archived Page - GeoNet, The Esri Community
But sadly, it has been archived.
Perhaps @MichelleMathias can revive it or copy the solution here
... sort of retired...
KevinHigh
Correct Answer
JustinLor
Thanks Kevin! That works and is very easy to do.
