ArcMap 10.8 Will Not Open After Install
5119
04-17-2021 03:54 PM
GabrielAttoun
I installed and authorized ArcGIS Desktop 10.8. I can open ArcCatalog. I cannot open ArcMap. The splash screen makes it through Initializing License, hangs briefly on Initializing Application, and then disappears. No error message.
What I've tried:
  • Disabling antivirus as well as excluding ArcGIS folder.
  • Changing the Python path, as well as uninstalling and reinstalling Python (I had multiple versions installed)
  • Uninstalling ArcGIS Pro
  • Checking Event Viewer logs (nothing)
  • Confirming that ArcGIS Administrator lists ArcGIS Desktop Advanced as authorized.
  • Repairing installation of ArcMap.
DanPatterson
MVP Esteemed Contributor
related perhaps, but this is for 10.7.1
It gives a few registry entries etc to check before reinstalling
Problem: ArcMap crashes during Loading Document launch stage (esri.com)
... sort of retired...
curtvprice
Also Resetting your ArcGIS application profile
and: make sure your windows default printer is set to a real device (or PDF) with current drivers.
RobertBorchert
Honored Contributor
Did you install Oracle 64 Bit?
