Arcmap 10.6 Display fails to update / refresh / redraw
1133
04-25-2019 09:58 AM
AlexanderBrodylo
Arcmap 10.6 for Desktop - So its been a couple weeks, if not a month since last starting up arcmap on windows 10 computer. Currently running through a few online course tutorials. Anyway, so while working initially with a basemap, the application soon fails to update the display 10 minutes into a particular arcmap instance starting.
It fails to acknowledge:
- Panning the display area
- Turning off/on different layers
- Switching between data frame, even between data view to layout view
- Zoom out/in
Tried removing basemap, and clearing display cache without any result.
Background processing is disabled.
Edit: while a new\fresh instance will help briefly, this issue will occur again as soon as the 'swipe' (viewer\button from image analysis or from effects toolbars) is used.
Have yet to find a similar post to this one (only one other found which didn't resolve issue).
If anyone has any ideas or suggestions, I would really appreciate it.
