ArcMap 10.5.1 connect to SSMS 19
1809
7
08-14-2024 03:59 PM
EllaDelaRosa
Hi Community
I'm trying to connect to a SQL database via ArcMap 10.5.1 on my windows 10 Enterprise. I'm getting the "Unable to connect to database server to retrieve database list......" error, as well as the "Connection was attempted with an older version of SQL Server Client communications software that is not supported" error. I have ODBC driver 17 and OLE DB driver for sql server. I use the same credentials in a remote connection to the non-production server, and on SQL Server Management Studio 19 on my PC, and it works there, but not in ArcMap or ArcCatalog.  Any ideas why?
Thank You
CodyPatterson
MVP Regular Contributor
Hey @EllaDelaRosa
I read in another post that issues may come up when more than one DB driver is used, the post mentioned that the user used ODBC 17 and uninstalled the others. Maybe that could be a starting point! Other than that, what version is your SQL server, and would it be possible to update your ODBC driver to a newer version?
https://community.esri.com/t5/arcmap-questions/arcmap-connect-to-sql-database/m-p/1194806#M3921
Cody
EllaDelaRosa
Thanks Cody!
I have SSMS 19.3, do I need OLE DB Driver 19? I currently have only the ODBC 17 and the OLE  DB 18. Do i need to download a later version of .NET Framework as well?
CodyPatterson
Hey @EllaDelaRosa
Since you're using SSMS, I would say first attempt to uninstall the OLE DB 18 driver if it is not being used, the ODBC and OLE DB drivers are similar and may cause conflicts, I would then try to install the OLE DB 18 driver and uninstall the other. If all else fails, attempt to install the ODBC 18 driver and leave OLE DB uninstalled for that moment. I assume it could be something to do with an incompatibility.
Cody
EllaDelaRosa
@CodyPatterson Thank you so much! I'll try that right now and let you know!
EllaDelaRosa
Hi Cody, I tried all your suggestions, and nothing has worked so far
CodyPatterson
Hey @EllaDelaRosa
That is pretty strange, but that's how troubleshooting can be sometimes! At this point, we've made about as many changes as I'd be comfortable with, if possible, I would reach out to ESRI Support to get a technician to check it out, it sounds like there could be an issue on the connection side, but it's difficult to tell from where I'm at.
Cody
EllaDelaRosa
Hi @CodyPatterson! Thank you so much for your help! I really appreciate it! I'll get in touch with Esri Support!
Thanks again!
Ella
