ArcMap 10.7.1 New to using scripting to help with adjusting formats and require an assist with my syntax. I tried to bring an excel already formatted, but looks like I need to save as DBF4, and this is not available to me. I'm working with APN numbers, and it would be helpful for them to be formatted ###-###-###. They are currently in field PARCEL_APN as #########.
use Excel To Table (Conversion)—ArcMap | Documentation (arcgis.com)
and see if it comes in properly as a text field.
If that doesn't work, you may need to do a field calculation in a text field using something similar to
(replace "a" with he field
"{}-{}-{}".format(!a![:3], !a![3:6], !a![6:])
