Add 1-day to today()
1916
10-16-2023 12:30 AM
JeffHouser
Hello,
I'm using ArcGIS Desktop.  I'm trying to update a date field in a featureclass using the following code:
rows.updateRow((datetime.date.today() + datetime.timedelta(days=+1)))
I'm just trying to add 1-day to today().  The above code is triggering a TypeError: argument must be sequence of values. Seems I may be using timedelta wrong?  Maybe there is a better way?
-Jeff
JeffHouser
Thank you Dan for you your reply.  I was already using your #4 example.  Looks like I had a paranthesis issue in my code. What I found out, I needed to change the code:
from
to
rows.updateRow([datetime.date.today() + datetime.timedelta(days=1)])
Thank You
-Jeff
DanPatterson
MVP Esteemed Contributor
As an example...
datetime.date(2023, 10, 16)
datetime.date.today() + datetime.timedelta(days=10)
datetime.date(2023, 10, 26)
... sort of retired...
JeffHouser
from
to
Thank You
-Jeff
