Energy based least cost path
3654
7
12-30-2017 06:55 AM
PanosTzovaras
Hi there,
I am trying to generate a least cost path taking into consideration the energy (calories) expended crossing a given distance. So I need to create a friction surface, based on a slope, representing the energy needed to cross a given distance.
I have made a similar surface by using the hikers equation. However, I don't know how can I do something similar but with energy.
Any suggestions/solutions?
Thanks
JamesNewhard
I and my colleagues played around with this issue in developing some LCP modelng for the Argo-Saronic region: Newhard, J.M.L., Levine, N.S., and A.D. Phebus (2014). "The development of integrated terrestrial and marine pathways in the Argo-Saronic region, Greece." Cartography and Geographic Information Science 41.4: 379-390. https://doi.org/10.1080/15230406.2014.925786.  We employed both several walking models (Tobler's and Naisthmith's) along with an effort algorithm that we pulled from a study conducted originally in Italy (citation escapes me).levinen
DanPatterson_Retired
Path Distance Analysis would be something to examine
PanosTzovaras
Thank you
JamesNewhard
PanosTzovaras
That's really useful, and really thorough research, cheers. So,  time-energy in one formula? Great. I used Tobler's equation too, and I was thinking to use Pandolf equation, but I am not so sure for the latter.
JamesNewhard
We're in the process of turning the model (originally worked out in ModelBuilder) into a more user-friendly process by streamlining out the processes in Python.  Eventually, the game will be pushed onto our GitHub.
PanosTzovaras
Well, that's a game changer. I will be on the look out to see how your work will be developped.
PanosTzovaras
For anyone interested or with the same issue:
Appart from James' solution, which I highly recommend, there is another formula (pandolf's):
Generate a slope (percent_rise), use the raster calculator and divide your slope in percent map by 100, giving you a dh/dx. Then use a formula {e.g. Pandolf's formula: M=1.5*W+2.0*(W+L)*((L/W)*(L/W))+η*(W+L)*((1.5*V)*(1.5*V)+0.35*VG) }*
Then you just have to covert KM per W to W per KM (1.0/output) and afterwards, if you want you can also convert to W per M (output2/1000)
*W=weight, L=external load in kg, V=walking speed, G=slope, η= terrain coefficient
