I have upgraded to 10.8.1, installed the Workforce general patch and Field Maps 20.4.0. When creating a new Workforce project, under the advanced tab, Field Maps do not show up in the App Integration Window. It shows Collector, Explorer, Navigator, survey123, but no Field Maps.
I've restarted computers and servers and logged out and back in, but no change. Field Maps functions correctly, I've mad a couple of maps. It seems confusing, when I launch the the Resources tab in Workforce project manager page it takes me to help that seems to be for the previous version, it talks about expanding the App Integration, but that was in the last version. Any Ideas?
Hi Craig - is adding callback to Workforce supported for Field maps assignment integrations?
If so can you share an example URL ? So far I have not gotten the callback parameter working to modify the default one
Thanks! Sue
Hi @SueEnyedy sorry for the delay; does using the callback parameters in Field Maps not return you to Workforce?
https://doc.arcgis.com/en/field-maps/android/help/deploy-your-map.htm
https://fieldmaps.arcgis.app?referenceContext=addFeature&itemID=3ac4145c1ac44aea86e9ed42e00fbb0d&featureSourceURL=https://services9.arcgis.com/QjGvjfQhsHAmqfjP/arcgis/rest/services/DamageAssessment_Apr2018_631d0895e7d3404bb78e8e04e92d896e/FeatureServer/1&callback=https://workforce.arcgis.app&callbackPrompt=Workforce
Hey @CraigGillgrass, any good news about the general patch for having the field maps into 10.8.1?
Regards,
Hello @Hussam_AlJabri I don't have any updates on the patch. It's still a consideration but other priorities are precede it. Our recommendation continues to be to use the Python API workflow to enable the Workforce to Field Maps integration.
Is the Python Script will add the Field Maps to the Workforce for all new upcoming projects or I have to do it every time that I need to create a project?
How I can configure it? Any guide to do so step by step?
@Hussam_AlJabri this will need to be run on each Workforce project that you'd like to integrate with Field Maps.
Please see this topic in the Python API:
https://developers.arcgis.com/python/api-reference/arcgis.apps.workforce.html#integration
Any help how has to be the python code to add the field map integration to workforce?
I am using ArcGIS Enterprise 10.8.1, is it supported?
I am trying:
I agree, I am far from a Python expert but I kinda want to try to set up this integration. I tried something very similar to David_RonaldSuárez_Urresti, running the Python viewer in Pro and changing the necessary info. Pro crashed. Is that the correct way to go about this?
