Select rectangle tool on the map is broken
1021
09-27-2024 12:21 PM
neomapper
I have noticed that when using the select rectangle tool on the map, records that are hidden behind a filter are showing up in the selection. Can you please explain why this is happening and how can I get it to only select what is filtered?
neomapper
neomapper
Found a solution
