Problems with encoding
2963
08-18-2022 02:35 AM
MaozTreeCare
Hello,
I'm using this script in order to get all my assigments.
https://github.com/Esri/workforce-scripts/blob/master/readmes/export_assignments_to_csv_readme.md
Some of the assignments text is in Hebrew.
The text i'm getting is:
׳ ׳©׳œ׳—׳” ׳₪׳ ׳™׳”: 28/04/2022 06:43׳¢׳¨׳ž׳” ׳©׳œ ׳’׳–׳ ׳¢׳¦׳™׳ ׳©׳œ ׳’׳ ׳™׳ ׳•׳ ׳•׳£
What I did:
I'm using
# -*- coding: utf-8 -*-
On the top of my python file.
I have opened the file with notepad++ and converted it to UTF-8 without BOM.
I'm using UTF-8 encoding while reading the file:
with open(arguments.csv_file, 'w', newline='', encoding='utf-8') as csv_file:
Is there anything i'm missing here?
Thank you
MaozTreeCare
Thank you!
I have managed to figure out the issue was not with GIS or python at all... but the Excel!
It did not open UTF-8 CSV files corretly...
I had to change the open code to
with open(arguments.csv_file, 'w', newline='', encoding='utf-8-sig') as csv_file:
only using utf-8-sig' (BOM) excel was able to figure out that the file is in UTF-8 format.
I should have checked the file itself, the text was written correctly...
Thank you
ShaunWalbridge
The header of the Python file only affects the encoding of the text within the script, so probably is unrelated. Opening the input with 'utf-8' looks correct, I would check that the database is correctly storing the information as UTF-8 (e.g. it wasn't reencoded into something else during storage), and you can stop your script at the point of execution to check what Python thinks its seeing. If you add `breakpoint()` to your code, you'll get the PDB debugger which will allow you to inspect the state.
MaozTreeCare
Thank you!
Thank you
