New Workforce Mobile App missing Basemap and Assests
7533
23
08-10-2020 02:12 PM
by Anonymous User
Not applicable
I am having trouble with my new Workforce Project. It seems the field guys can't see anything beyond the assignments layer and thier worker layer in the field map. No basemap and no asset layers that I published that are both in the Worker Map. All the layers are shared the same way, I have not moved any layers in agol out of the folder and I did not this problem before in Workforce Classic. This is a brand new project and I haven't made an edits.
I can get our asset layer and the basemap to show up if I create an offline area.
Finally, if I do not create an offline area the project will not download to a mobile device.
Any ideas would be greatly appreciated.
CraigGillgrass
Daniel, a couple questions,
What type of layer is this and how many features are in it?
Are you able to take that same layer offline in a map using the new Collector?
If you create a Map Area in Workforce; does this layer appear?
Craig
DCMcLain
This is a hosted feature service with 8 layers (points, and lines).  Total features - 2,246,164
It does work in Collector for this same project.
It's not allowing me to create a Map Area.  I keep getting this error.  But I can't identify what's not being shared properly.
CraigGillgrass
Daniel,
I'm guessing that is the Workforce worker web map and the Workforce feature service.  Can you confirm they are shared the same way?
Craig
DCMcLain
The Workforce worker web map and the Workforce feature service are shared the same way.  I'm borrowing the Facilities layer though that's blocking the download..
CraigGillgrass
Hi Daniel,
It sounds like this is going to be a bug somewhere that we should look at.
Can you expand a bit on what you mean by "borrowing"?  Copy/paste of the sharing info might help too.
Craig
DCMcLain
I'm not the Owner of the layers causing the problem.  They were shared with me from another publisher in my organization.
Do you mean copy/paste the icons in the Content folder showing which groups the layers are shared with?
CraigGillgrass
Hi Daniel,
Your description helps, we'll try and repro it here.
Craig
DCMcLain
I was able to enlist our support specialist here and she found that it's the grouped layers that's causing the problem.  The sharing works fine as long as you add individual layers.
CraigGillgrass
Hi Daniel, unfortunately, Group layers are not yet supported by Workforce.
Craig
by Anonymous User
Not applicable
Hi Craig,
If you want more test cases, I'm also experience this issue. Mine has a slightly different scenario. I have changed the base map to the ESRI hybrid imagery layer, with no custom layers. The dispatcher map can see the this Hybrid layer, however the mobile devices only displays the default Topo layer. It would be nice for the fieldworkers to see the same layer as the dispatcher. I have approximately 630 assignments and this fix would help the inspectors immensely!
Paul
ArcGIS Workforce
