Assignment Monitor Python Script not working
3765
8
11-15-2018 10:44 AM
LaneHartman
I am configuring the assignment monitor python script and it seems to be hanging up on my organization URL.  I've tried at least 5 different versions of my URL (with https://, without https://, with a / at the end, without, etc).  The error I keep getting is below:
(arcgispro-clone-new) C:\xxxx\assignment_monitor>python assignment_monitor.py
[2018-11-15 13:12:42,869] [ assignment_monitor.py: 155 - <module>()] [MainThread] [ root] [ INFO] Authenticating with ArcGIS Online...
File "assignment_monitor.py", line 159, in <module>
verify_cert=False)
File "C:\Users\Lane\AppData\Local\ESRI\conda\envs\arcgispro-clone-new\lib\site-packages\arcgis\gis\__init__.py", line 273, in __init__
raise Exception("Malformed url provided: %s" % url)
Exception: Malformed url provided: <https://xxxx.maps.arcgis.com>
Any ideas?
by Anonymous User
Not applicable
Oh sorry, there also shouldn't be any quotes around it.
Here is my example:
# workforce/agol project id
[WORKFORCE]
PROJECT = 7dc1bd9bdffe4adeb5adcafXXXXXXXXX
# slack webhook
[SLACK]
WEBHOOK = https://hooks.slack.com/services/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
# AGOL auth info
[AGOL]
ORG = https://arcgis.com
USERNAME = workforce_scripts
PASSWORD = password
# log file
[LOG]
LOGFILE = log.txt
[DB]
DATABASE = assignments.db
by Anonymous User
Not applicable
It looks like you might be putting the url inside the angle brackets. Try "https://arcgis.com" instead of <"https://arcgis.com">. The angle brackets are just meant to denote that it's a template that needs to be filled in. Hope that helps.
LaneHartman
Aaron,
I tried that, but still get the same error. It just replaces the angle brackets with the double quotes. Here is the full config.ini file for the assignment monitor Script in case I’m missing something else.
[WORKFORCE]
PROJECT = xxxxxxxxxxxxxxxxxxxxxxxxx
# slack webhook
[SLACK]
WEBHOOK = https://hooks.slack.com/services/xxxxxxxxxxx/xxxxxxxx
# AGOL auth info
[AGOL]
ORG = "https://xxxx.maps.arcgis.com"
USERNAME = xxxxx
PASSWORD = xxxxx
# log file
[LOG]
LOGFILE = log.txt
[DB]
by Anonymous User
Not applicable
Here is my example:
[WORKFORCE]
# slack webhook
[SLACK]
# AGOL auth info
[AGOL]
PASSWORD = password
# log file
[LOG]
LOGFILE = log.txt
[DB]
LaneHartman
Yes, the script works fine now. Is there a way to change the fields that appear in Slack?  I'd like to have the assignment type in there also.
by Anonymous User
Not applicable
Awesome. Glad you got it working. You can modify the function in the script here: workforce-scripts/assignment_monitor.py at master · Esri/workforce-scripts · GitHub
I believe this would show the assignment type (haven't actually tested it).
def post_to_slack(slack_webhook, assignment):
    Posts a message to slack
    :param slack_webhook: (string) The url of the slack webhook
    :param assignment: (Feature) The feature to use
    :return:
    # create the message to send
    message = """
    *Assignment Completed*:
    *Assignment Type:* {}
    *Location*: {}
    *Description*: {}
    *Notes*: {}
    *Worker*: {}
    *Time*: {}
    *Link*: {}
    """.format(
        assignment.assignment_type.name,
        assignment.location,
        assignment.description,
        assignment.notes,
        assignment.worker.name,
        assignment.completed_date.strftime("%Y-%m-%d %H:%M"),
        "https://workforce.arcgis.com/projects/{}/dispatch/assignments/{}".format(
            assignment.project.id,
            assignment.object_id
    logging.getLogger().info("Posting: {} to slack".format(inspect.cleandoc(message)))
    response = requests.post(slack_webhook, json={"text": inspect.cleandoc(message)})
    logging.getLogger().info("Status code: {}".format(response.status_code))
LaneHartman
Yes, that works perfect.  I had just dug into the schema of the feature class and found the domain name when you replied.
Thanks!
LaneHartman
Also, the time field is 5 hours later than my current time in the Eastern Time zone which I assume is UTC.  Is there a way to display the time stamp in Slack as the Eastern time zone by modifying the assignment_monitor.py script? I tried to modify Line 63 as shown below, but that didn't seem to have any effect on the output.
assignment.completed_date.strftime("%Y-%m-%d %I:%M %p")
by Anonymous User
Not applicable
You could try using the arrow module (you'll have to install it with pip/conda). This should handle daylight saving and what not.
Arrow: better dates and times for Python — Arrow 0.11.0 documentation
Then you could do something like:
d = arrow.get(assignment.completed_date)
eastern_date = d.to('US/Eastern')
eastern_date_string = eastern_date.strftime("%Y-%m-%d %H:%M")
