We have a ArcGIS enterprise with workflow manager. We did an upgrade from ArcGIS enterprise 11.1 to 11.5 last week following this instructions https://doc.arcgis.com/en/workflow-manager/11.5/deploy/windows/existing-workflow-manager-server-user...
. We notice in one of the hosted workflow_views that v_job_search and v_job_search_ext layers the object id add a - (hyphen, negative, minus) to the object id number after a update to this new version.
and when we are trying to use select by attribute using jobname column we get an error saying "error 160760 FIDs must not be negative"
Has anyone seen this behavior? is there a way we can remove the (-, hyphen, negative, minus) from object so we can to make it work again?
Diego Llamas
