Visual Studio 2010
2469
09-22-2011 07:28 AM
JamesVillanueva
Does the Workflow Manager SDK support Visual Studio 2010?
TopeBello
You can use the SDK with visual studio 2010. The references do not show up under the .NET reference tab but you can add the reference needed by using the browse option to navigate to the bin directory that contains the libraries.
Tope
JamesVillanueva
Is there a timeframe for seeing full integration into the Visual Studio 2010?
TopeBello
Yes, this will be at the next release sometime next year. ArcGIS Desktop SDK also does not have such integration hence the reason why this is not yet included in the product. This integration will be available at 10.1 release.
I hope that helps.
Tope
FabianHeredia
hi
i need run to debug in vs 2010 but don't see the atthach to process.
FraserHand
What version of Visual Studio do you have? It is only available in the Pro, Premium and Ultimate editions.
See http://msdn.microsoft.com/en-us/library/c6wf8e4z.aspx
Ta,
Fraser
