Unexpected message received Failure(java.net.ConnectException: Address already in use)
2553
07-30-2023 04:16 AM
Ranga_Tolapi
ArcGIS Workflow Manager: Version 10.9.1
High-Availability Enabled: Yes (2 Nodes)
OS: Windows Server 2022
Noticed below messages in the Workflow Manager logs.
Unexpected message received Failure(java.net.ConnectException: Address already in use: no further information: <hostname>/<ip address>:443)
No buffer space available (maximum connections reached?): connect: <hostname>/<ip address>:443)
When the above error occurs, Workflow Manager is becoming completely unresponsive (Workflow Manager Server web page showing infinite loading icon). It's coming back to normal only after restarting the machines.
@JFarmer requesting for your valuable response please.
JFarmer
Hi @Ranga_Tolapi
I'm aware of this issue you've reported and this one: https://community.esri.com/t5/arcgis-workflow-manager-questions/fatal-sorry-too-many-clients-already....
We've been chatting with Tech Support on this but this looks like a core ArcGIS Enterprise issue from what I've seen so far. It seems like a Data Store user connection limit issue or some other Data Store issue to me. Has that been looked into? I think the Workflow Manager side of this is just the symptom of a problem with Data Store.
I'm not aware of any other users that have reported this issue so I don't have a specific answer here. It may be best to continue working with Tech Support (and we can as well as needed) to see where we can get there.
Jonathan
Ranga_Tolapi
Hi @JFarmer
For now, we added below registry entries with Decimal values and restarted both the WFM machines.
  • MaxUserPort (65534)
  • TcpTimedWaitDelay (30)
Not sure this can address the issue fully or not.
