Import users from JTX 9.3.1 to Workflow manager 10
2899
07-28-2011 12:09 PM
CraigMark
Is there a template to use for the import?  I've created a few users in WMX 10 and successfully exported the user.jxl.  I just need the format for the import.jxl.
Any help is greatly appreciated!
- Craig
TopeBello
Hi Craig,
There are 2 templates provided with ArcGIS Workflow Manager install.
Minimum Configuration - gives you the minimum configuration elements needed to use workflow manager
Quick Start Configuration - provides you with sample users, groups, workflows and job types that you can use in addition to the contents of the minimum configuration file.
Once you have the base configuration imported to your 10 repository, you can import your old configuration into the 10 database by using the merge option during import.
Have you tried this? If so, do you receive any errors?
Tope
CraigMark
Tope thank you for the reply.  Sorry if my question was not clear.  I'm trying to migrate our users from JTX 9.3.1 to WMX 10.
I've successfully exported a user in WMX 10 (to create a template for the import).
Is there a template that I can use to be able to import users?  I've tried to cannibalize the exported .jxl and I'm guessing that I just need the header for the user import  in the .jxl.
Thanks
- Craig
