Error 000819: The tool is not available or is unassigned
8819
12
11-04-2016 11:45 AM
ErnejunCorvera
I tried to create workflow database using Create Workflow Database tool but returns an error 000819. I have an advance(personal) desktop license with ArcGIS workflow manager installed.
Create workflow database error
JayantaPoddar
Did you turn on the extension for Workflow Manager (Customize > Extensions)?
Think Location
ErnejunCorvera
yes, extension is on both arcmap and arccatalog.
ErnejunCorvera
JayantaPoddar
Not sure if it will work but worth a try.
Open ArcCatalog > open ArcToolBox > (If WorkFlow Manager Tools is not available, add it to ArcToolBox).
Repeat/Check the same for ArcMap.
arcgis desktop - "ERROR 000819: Tool is not assigned" While Running Spatial ETL Tool? - Geographic I...
Think Location
ErnejunCorvera
I added the workflow manager tool in arccatalog and arcmap but still no luck......hope someone can solve this problem of mine. anyway, thanks Jay for the effort on helping me on this.
ErnejunCorvera
I finally solved the problem by disabling Background Processing from Geoprocessing option....
RebeccaStrauch__GISP
Make sure to make this as answered so it can be closed.
VítorAntão
Me to. Disabling the background processing resolved the problem.
XiaomengZheng
This was a bug in versions prior to 10.5 and we have fixed this issue in 10.5. Sorry for the inconvenience.
