Define AOI by entering coordinates
2210
05-31-2012 07:39 PM
TrevorHart1
Is there anyway to get the "Define AOI by entering coordinates" tool (on the Define Jobs Spatially window) to show other coordinate systems? Its very unhelpful when the only options are WGS84.
Not to mention the users are confused when they are confronted with options for DMS, DDD etc
Other than that can the tool be removed?
KevinBedel
Hi Trevor,
Right now, there is no way to use a spatial reference other than WGS84. It is possible to remove this command from the AOI panel by updating the JTXUIConfig.xml, but there is no way to remove it from the Define Jobs Spatially window. We are currently investigating ways to improve this functionality to handle other spatial references in the future.
Kevin
TrevorHart1
Thanks kevin, I will give that a try. Is JTXUIConfig.xml a client side file?
KevinBedel
Yes, the JTXUIConfig.xml file is located on each users machine in the <WMX install>\config folder.
