Is there a way to manage feature templates in the web editor? Since the June 2024 AGOL update the manage button has disappeared in the map viewer classic maps. I would like to move the workflow into the web editor or map viewer but can not find a way to manage the feature templates.
Thanks!
@DeniseJensen_wgfd thanks for your question. The ability to manage feature templates is not in Web Editor but it is a project that is being worked on. The current plan is for this to be available in Map Viewer with the Fall release of Online later this year.
We don't have any plans to also include it in Web Editor, as we'd like to keep the Web Editor focused on editing tasks and workflows, with authoring tasks and workflows done in Map Viewer.
Craig
@CraigGillgrass Thanks for the update! It will be great to have it in at least one of them so we can move away from classic. Any thoughts on why the manage button went away in classic? We still need the functionality between now and fall.
I’m sorry you’re having trouble managing templates. The ‘Manage‘ button has not been removed from Classic. I am able to see it. If you are not seeing it, there must be a problem. You may want to reach out to support to log the issue.
In the meantime, you can use Field Maps Designer to manage templates in ArcGIS Online. To get started, follow these steps:
Hope that helps!
If it hasn't been removed, where is it hidden now?
This seems to be across the board with ALL web maps I tried.
R_
@RhettZufelt it's not been hidden, I can confirm it's still there and available. Maybe this is a permissions or licensing issue - what is your usertype and role? In the example you show above, do you own the map and feature services in the map?
@EmilyGeo Thanks! I will submit a ticket. It seems everyone in my organization is having the same issue. Thanks for the work around as well!!
I submitted the ticket to ESRI and this is what we found out. If you open an existing Map Viewer Classic map the manage button will not show up. If you go to the feature layer Overview page and on the right say open in Classic then the manage button will be there.
They have submitted it as a bug but with Classic going away, it may not be fixed. They have also reached out to the Map Viewer team to see about getting the manage button in Map Viewer as a higher priority. So we will see what happens.
